Help separating screen from frame
Hi, I'm strugging with removing the display as described in step 30 of this guide:
Galaxy S6 (Verizon) Charging Daughter Board
I've destroyed two displays trying to slip the guitar pick between the frame and the display. Each time I end up sliding the pick underneath the black backing of the LCD exposing the silver material inside the LCD. In the guide it shows the blue pick sliding from the outside of the frame and then being visible when it reaches the inside part of the frame. Whenever I do it, the pick slides under the frame and is not visible when it reaches the inside portion of the frame. I am using heat to soften the adhesive.
Please help!
See attached image.
Questa è una buona domanda?
