Help Screen replacement problem
I did a screen replacement and everything works when i attach the new screen (the connector piece) but when i try to glue the screen onto the phone it goes black or has no backlight ?!.
Questa è una buona domanda?
There is either damage present on the flex cable, the connector for the display is coming loose when laying the screen down, or something on the back of the display flex cable is grounding out on the frame and causing the no display issue. I would compare the back of the new screen to the back of the old one (if not completely destroyed) to ensure that they look the same and the new one isn't missing any type of tape or covering.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
