Salta al contenuto principale
Waterproof action camera (model no. CHDHS-101) released by GoPro in July 2015. The Hero4 Session shoots 1080p video and 8MP stills.
24 Domande Visualizza tutte
How do I get a jammed sd card out
my sd card is jammed in my go pro and when you push it in it goes to one side please help
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Cut a plastic playing card the same width as the SD. Don't cut the length, leave it long.
(Business cards are soft paper and too thick.)
Slip it down alongside the stuck card until it seats firmly in the socket.
Wiggle both cards, held together as one, when you try to remove them.
Try each side of the SD card. ( It may be stuck by the contacts.)
If it refuses, slice another card and make a SD sandwich. Newer devices, like your GoPro, may not allow a 'thick' card.
I have used this trick many times on my old Sony camera.
If this card-trick fails, you'll need surgery !
Do not try to yank/force it out.
2 years ago, we had a SD card split apart inside my laptop. The label half came out, but the contact side stayed. Since the device was part of the mainboard and not replaceable,,,, its still in there !
Punteggio 2
1 Commento:
Awesome trick. Thanks it helped!
da
Aggiungi la tua risposta
Harley whiteman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 57
Tutti i Tempi: 6,753
