Salta al contenuto principale
Model: HX9300 Series The Philps Sonicare DiamondClean Series can be identified by its model family number: HX9300. All HX93xx models are the same toothbrush. The third and fourth number determines the contents of the box. The numbers after the slash (/) determine the color of the handle.
15 Domande Visualizza tutte
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Questa è una buona domanda?
Punteggio 0
1 Commento
I have probably a similar issue. Who can find and change a battery here?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Punteggio 3
I'm having the same problem. Have you fixed it?
Thanks!
Punteggio 1
2 Commenti:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
da
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
da
Aggiungi la tua risposta
swat1230 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,054
