Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
304 Domande Visualizza tutte
Craked screen Glass or entire display broken?
Dropped the phone while running for a train smashed on the floor and well is basically useless since, Went into repair shops and without even looking at it they say it would be 320 euro to fix. The touch still works but the screen flashes when I turn it on and flashes white and black all over if you need pictures let me know.
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello,
If there is effects on the display then the whole digitizer is probably at fault, so I'm afraid you would have to change it all
There is also a small probability that the fall damaged directly the motherboard, causing those problems, but it is far less common
Punteggio 0
Aggiungi la tua risposta
Conor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 71
