Salta al contenuto principale
Series of HP Pavilion laptops released in 2015. The 15-p is more difficult to service then later 15-x models.
23 Domande Visualizza tutte
Recieved a slightly different battery model then the one I ordered
The battery my laptop uses is an HSTNN-LB61, unfortunately its reached the end of its useful life. I searched for the model of the battery, and ordered a battery that was the same model, BUT what arrived was an HSTNN-UB6K . Now, the battery fits perfectly, its the same voltage, but with a slightly different capacity. I just have a slight concern: Is it safe to use this battery? Thank you for your support!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Capacity difference is fine. If it is a larger capacity it simply means it lasts longer on battery.
Punteggio 4
1 Commento:
both batteries are 14.8 volts and 41 watt hours. I am using this new battery now and its working fine!
da
Aggiungi la tua risposta
Bryan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 113
