Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
iPhone 6s Plus No Service but Have IMEI when dial *#06#
Hye I got an IPhone 6s Plus for No Service issue. When dial *#06# showing perfect IMEI Number, also the setting showing IMEI and Modem Firmware Version.
No Water Damaged history on this board. I do a little diagnose around the U_WTR_RF showing good measurement (PP_1v0_LD09). I never see people are talking about this issue on the internet. Seems like this case are very rare.
Where should I start first ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
possibly u_pmu_rf. check out this video. https://www.youtube.com/watch?v=m2RDrOG_...
Punteggio 1
2 Commenti:
I already watch this video. But the guy in the video not telling anything. Not explaining what his doing. Syok sendiri kot
da
if you can reball ics then i would try reballing u_pmu_rf to see if it solves the problem. if you do that and it doesnt work the you have eliminated that from the problem
da
Have you checked the IMEI to see that it is not carrier locked?
Punteggio 1
Aggiungi la tua risposta
Azim WHITE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,130
