Salta al contenuto principale
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
612 Domande Visualizza tutte
Replace the Camera Protection Lens
Hi, I noticed there did seem to be a video on how to replace the Galaxy S5 Camera glass cover. My brother in law replaced one a while back but the camera never focused right, so since I got my iFixit tool kit I decided to try and free up whatever glass was stuck inside and replace the cover.
I tried almost everything from canned air to pushing a brush inside to bopping the phone to knock the glass loose that must have been inside, finally I took my fine angled tweezers and tried literally pushing the lens around by not touching the glass. I even got pretty firm using a bit of pressure. That did the trick, at least for now.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
1 Risposta
So... is there a question you need to have answered?
Punteggio 0
Commenti:
Is there a procedure somewhere for this? And what tool should I have used to dig under the lens cover?
da
you will need a precision knife set to get the old lens cover off which can be found here: https://www.fixez.com/precision-knife-se...
you will need double sided adhesive to place the new lens cover on: https://www.fixez.com/categories/repair-...
you will need a new lens from here: https://www.fixez.com/store/samsung/sams...
how to video can be found here: https://www.youtube.com/watch?v=JeAW4Jut...
da
Aggiungi la tua risposta
Mark Hayward sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 97
