Salta al contenuto principale
Una collezione di guide e supporto per l'aiuto alla riparazione di lavatrici.
20 Domande Visualizza tutte
Lg wd80130f doesn't spin fast
Hi, my lg wd80130f does not spin fast after completing its wash cycle hence leaving clothes wet, sometimes it works if i unplug amd start the whole washing cycle again. When it doesn't spin after cycle, i can hear noise like relay is switching and light sound of motor who is trying to spin, but it can't.
From few days i let it complete its cycle and then i will go into its QC test mode and spin it from there. It works everytime but i want to fix it because if it fails to spin then it won't turn off and on few occasions (if i leave it anattended) it will keep running for overnight.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
REF: http://diagramas.diagramasde.com/otros/L...
The link above is the service manual for you washer. Start on Page 25 for troubleshooting the spin cycle.
Other thoughts: When you do the QC test, I'm assuming this is done with the basket empty. Is the water draining after the wash cycle? If not, look at Page 18 "Drain Trouble" and Page 23 for drain malfunction. Excess weight caused by water drainage issue would affect spin speed.
Punteggio 0
Did you find out what the fix was? I am having the same
Punteggio 0
Aggiungi la tua risposta
manubali811 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 7,166
