Claw won't move side to side
My claw won't move left to right even though I hear the gears moving. Why is this?
Questa è una buona domanda?
Punteggio
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 68
@ninjashadow3
If you heard gears moving, you need to check if the traverse mechanism is engaged properly / blocked / broke. take some pictures.
The Claw Item Replacement
da Augustine
I had the same problem; blame flimsy construction. In my case the gear, which was made of the world's cheapest plastic, had partially worn JUST enough to make the thing skip. A friend of mine 3D printed me a new gear and after some careful disassembly, reassembly, and a couple dabs of hot glue, it worked again.
da Steve
