Hey guys,
I just installed an iFixit battery in my daughter's iPhone 7 with iOS 12.1.2 and the Battery Health feature works. Maybe apple corrected this or the battery is compatible with this feature now.
I received this straight from iFixit support:
Thank you for contacting us about your battery health!
We are aware that Apple's iOS 11.3 update includes a beta release of the Battery Health feature. Some customers have already reported the same scenario with their device -- the battery is unable to determine it's current health state -- which has lead to them believing that their battery is defective. This is not indicative of a defective battery, simply iOS 11.3's lack of ability to read the diagnostic data from the battery at this time.
It is our current understanding that this feature may not operate with iFixit batteries as our batteries are not manufactured by Apple. That being said, iOS 11.3 is so new that it is possible there will be a patch coming soon that may enable your iFixit battery to work with this feature. We encountered a similar issue in the last Apple update, 11.2, where we saw a rise in users report sudden touch response issues after updating their phones to iOS 11.2 (which even affected users who had never replaced components on their device). Apple later rolled out an update that corrected this issue.
If the battery you have installed is not prematurely shutting down or otherwise behaving strangely, you can try rolling back your iOS to 11.2 and wait until Apple releases a patch to fix this issue.
Thanks!
iFixit Support
My response was:
I just hope they do, with iOS 11.3, the device will have performance management. I don’t have problems with the iFixit batteries but If its not working you can’t disable the slowdowns in the Battery Health screen under Peak Performance Capability since is not displaying anything.
Basically all phones with aftermarket batteries will start slowing down when battery starts loosing capacity while original battery users will have peak performance until is time to replace the battery.
Thanks for the detailed reply
Votato
Annulla
Punteggio
10
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
12 Commenti
I don't understand the question.
Is there a specific feature in 11.3 that you cannot use?
OR
Are you unable to install 11.3?
da Telan
Can you post screenshots what you are seeing?
Also, what is coconut battery reporting?
da S W
He's talking about the battery health feature in the iOS beta, only seems to read from OEM / original batteries and not aftermarket ones.
da Ben
What he is talking about is that the new feature Battery Health Beta on iOS 11.3 is suppose to show you your Maximum Capacity and Peak Performance Capability, instead is showing that is unable to determine battery health. I have an iFixit battery not an original apple one also. See pictures below under answer.
da Victor R
Same issue here, iPhone 6s Plus. I just replaced the battery yesterday and updated iOS this morning to 11.3. Mine does say "Peak Performance". So I do not believe it will throttle it if it cannot determine the battery capacity.
da Justin Durham
Mostra altri 7 commenti
