Salta al contenuto principale
A collection of guides and support to help with washer repair.
3478 Domande Visualizza tutte
LG front loader won't drain
I have an LG front loader that won't drain. I can hear it buzzing like the drain motor is trying to drain, then I get an "OE" error ("no drain" issue), and it stops without spinning.
So, I removed wet clothes, drained the washer manually and checked the drain filter/trap (it was clear). I then turned on the drain/spin cycle with an empty load and it worked (started spinning).
I put the very wet (soaking) clothes back in, started the drain/spin cycle and I hear the drain motor trying to drain and then get the OE error again and no spinning.
I tried a master reset as described in LG WASHER won't drain or spin. No joy.
Any suggestions on what to try next. Thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
So, I called in the professionals - he said it was a problem with the pump impeller. Cost to fix is $311.
Punteggio 0
3 Commenti:
What is the reason our clothes sour after washing in cold water
da
Do I need a trap on my drain
da
The water sits in the pump and sleeps through into the impellers trapping stagnant water so I would say you need a new pump
da
pump out of my washer
Punteggio 0
pump out of washer
Punteggio 0
Aggiungi la tua risposta
bocotim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 14,894
