HTC 10 Display Half Broken After Screen Replacement. What's Wrong?
The battery on my HTC 10 was completely shot and needed to be replaced. I'm a careful person by nature and this being my first phone repair, I bought an extra screen just in case something happened getting it apart. Followed a guide by jerryrigeverything on how to take apart the phone, got the battery replaced, everything seemed to go smoothly. When I went to test the display before screwing everything together, the new screen I installed lit up, but the right half of the display only showed as a repeating segment from the middle of the screen. Thinking the connector was loose, I disconnected and reconnected the display and made sure everything was tight: same problem. I reinstalled the original display, which I made sure had worked after cutting through the adhesive before I disconnected it, and now the old display is also showing the same issue.
The touch screen on the broken side of the display still works, I'm able to type PIN numbers and whatnot even though I can't see them properly. Only thing I can think of is maybe the connection actually got some debris or something inside of it? I don't think I damaged anything, as I was super careful, but it was also my first time opening up a phone.
Sorry for the inefficiently worded post. Any help would be really appreciated.
Questa è una buona domanda?
