Salta al contenuto principale
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why isn't the flip cover settings working anymore?
I don't see the clock anymore in flip cover window after pressing power button. I see the home screen. Also when I open the flip cover screen stays black for so long I tap the screen to get to my home screen. This was working perfectly weeks ago. Settings haven't been touched and flip cover settings is on. Phone is so much slower over all even after boosting. Deleted many apps still way slower. Was great initially but not the same now. Using Evie.
Questa è una buona domanda?
Punteggio 0
2 Commenti
After restarting my phone and disabling some apps it started. Working again.
da
Maybe post that as an answer so this shows up as solved? That way, others with the same problem will find this post.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Punteggio 0
Hey Jody,
It sounds like you may have a broken (or blocked) IR proximity sensor. I believe the sensor comes with the display assembly, so it may be as simple as replacing the screen, but I/you will need to check. If it is, check out this guide.
Hope this helps,
-Tanner
Punteggio 0
Aggiungi la tua risposta
Jody sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 429
