Xbox won't turn on
I had to manually eject a disc from the Xbox. I had trouble with getting the disc out and eventual the disc came out. While i was taking the disc out the Xbox turned off. Now the Xbox will not turn back on. When I press the power it flashes on and then goes back off. I have tried many things including trying to fix the power brick. None worked. Help Please.
Questa è una buona domanda?
check the power supply LED, is there anything? if there is a power issue the LED will either be white (everything is good with power), steady orange (power supply is in power saving mode), no led or flashing orange (issue with power supply. if the supply is in the white it could be a video issue, in which case you would need to check the hdmi. if that is not he issue it could be a logic board problem.
da Joe
I think it may be a logic board problems. Is there any way to fix that? The reason i don't think it is the power brick is because I used it on a different xbox after mine broke and it worked even though it is orange now.
da Chris G
