Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Headphone and ear speaker not working after battery replacement
I decided to dive inside my iphone after my battery became pretty much dead. Got a new battery from scandiTech and did the replacement myself, everything seemed fine untill I tried to make a call, i couldn’t hear a thing from the ear speaker so i thought i had broken the ear speaker’s flex cable but upon using a headphone which too didn’t produce any sound I concluded that the problem is not from the ear speaker cable, the control buttons on the headphone works normal. The music speaker works fine too. Please can anyone help, i’m not ready to get a new phone.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Unplug the battery and reseat the screen and charging port ribbon cables.
I can't really see how those go faulty if you disconnected the screen after unplugging the battery during battery replacement.
Punteggio 1
Im not sure about iphone 6 but i know one iphone 5S that did get reversed problem, no music sound but ear speaker worked.
A small metal part did get bended when the battery connector was set down .
remove the battery connector and the lightning connector and around that there is smal protecting tape, remove that and look around the battery connector if you see any metal parts or components that are bended/moved or hits any other component.
Punteggio 0
here’s the problem 90% of the time. Someone tore this cable and refused to take responsibility. I replaced it for them. (See photo)
Punteggio 0
Aggiungi la tua risposta
Speedy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,517
