Hello Kelsea,
To be clear, it sounds like after the second visit, your earpiece speaker (at the top of the phone) now has very low volume and the loudspeaker (at the bottom) does not work at all. Is this correct?
The easiest way to get at the battery adhesive pull tabs on an iPhone 5s is to remove the loudspeaker first. The technician may have taken the loudspeaker out and accidentally bent one of the connection pins before putting it back in. This would be an easy mistake to make. It's also easy to fix.
The earpiece situation concerns me though because it is not so easy to cause this problem in error. Let me take you through my thought process. Each of your three problems has several common or likely causes:
1. Poor Battery life
A. Normal aging of the original battery
B. Poor quality new battery installed
C. High power consumption by phone due to previous water damage.
2. Loudspeaker does not work at all
A. Loudspeaker misaligned by technician
B. Technician damaged audio amplifier on motherboard by accidentally hitting it with a tool.
C. Loudspeaker damaged or audio chip on motherboard damaged by water-damage.
3. Earpiece speaker volume very low
A. Earpiece hole clogged with dirt
B. Cable leading to earpiece damaged by technician.
C. Technician damaged audio amplifier chip on motherboard by accidentally hitting it with a tool.
D. Earpiece speaker or the cable leading to the earpiece damaged by water.
So while at no point above did you mention water damage, I suspect this is also a possible cause of your many issues. We know a technician openned your phone, possibly touching each of these systems. However to cause these three symptoms, the technician would have to make a series of 2-3 separate mistakes. On the other hand, only a single instance of water damage could have caused all three symptoms.
Do you think there could be a history a water damage with you phone?
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
