Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2473 Domande Visualizza tutte
Back camera gone after water damage
Got an iPhone 6s with some water damage. Managed to get back everything to working order except for back camera. Since it was missing PP2V85 I removed U3200 which had suffered a short with VccMain.
Unfortunately CAM_EXT_LDO_EN seems to be missing too, although the pin is shiny and undamaged.
Does CAM_EXT_LDO_EN show up only when camera cable is connected or should I just say goodbye to the main camera ?
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey Arbaman, what do you mean exactly when you say "CAM_EXT_LDO_EN seems to be missing too"? Do you mean the signal or something physical?
I don't remember probing that before but looking at the schematic, it is connected to a UART RTS (Request To Send) pin on the CPU (maybe they ran out of GPIO's!?). Normally, an RTS will go high to initiate a conversation so that's probably what they do here as well; RTS goes high and enables U3200. If you not seeing a signal, you could always pull it high via PP1V8 (or use a DCPS) to see if that enables the camera.
Punteggio 1
Commenti:
@refectio Hey Minho, sorry for my lack of precision but I'm pretty new to iPhone repair attempts..would need some training..lol
Anyway you read my mind, I referred to the missing CAM_EXT_LDO_EN signal which should be enabling U3200 and create the needed 2,85v missing right now.
I will try to run a 1,8v bridge and see if that does the trick..thanks for help for now
da
Aggiungi la tua risposta
arbaman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 229
