Salta al contenuto principale
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
17 Domande Visualizza tutte
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
Questa è una buona domanda?
Punteggio 3
1 Commento
My breaks ar light weight
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
Punteggio 1
Aggiungi la tua risposta
Joseph Fernandez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 668
