@boiiii start by making sure you back-up all of your files. Then do a hard reset. Here are some instructions:
It is highly recommended that you complete a backup of the device information and disable Device Protection before proceeding with the steps in this tutorial.
With the device turned off, press and hold the Volume down key.
Note: If Device Protection is not disabled, the login credentials for the Google account currently associated with the device will be needed to set up the device after the reset.
With the Volume down key held down, press and hold the Power key.
Release both keys when the Android screen appears.
Use the Volume keys to scroll to RECOVERY MODE.
Press the Power key to select RECOVERY MODE.
When the No command message appears, press and hold the Power key.
While holding the Power key, press and release the Volume Up key.
Note: Release the Power key when the Android Recovery screen appears.
Press the Volume down key to scroll to Wipe data/factory reset.
With Wipe data/factory reset highlighted, press the Power key.
Press the Volume down key to scroll to Userdata only, then press the Power key.
Once the wipe is complete, with Reboot system now highlighted, press the Power key.
The device will restart.
The device is now reset and ready for use. from here.
If that still will not resolve the issue, you most likely need a new display assembly since that is where the "ghost touch" usually originates from.
Votato
Annulla
Punteggio
2
Can screen protect be the course too?, CU's after putting a screen protector on my phone yesterday after noon it starts operating it self this night please some one help me,am using Lenovo p1
da Francis Oyema
i have a ZTE max phone buut I've had it less than a year and its really making me mad
da Savanah E
My itel s15 keeps pressing itself without me touching it
da Sowunmi Joseph
I have this problem and I tried removing my screen protector and cleaning it and it’s the same
da Yolo Is God
Hi all, thanks for information. I checked screen protector and different things.
I even reset my whole phone nothing worked so in the end I just bought a new phone. Hope the ones who having same issue can find out the cause and get it sorted.
da Shannon Woodland
Mostra altri 24 commenti
