Salta al contenuto principale
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
wires came loose as I was removing battery, how to repair?
I was following instructions to remove the battery from my Flip Mino Hd. I hadnt used in it years and tried all else to turn on an retrive video. Noticed two wires unsoldered from motherboard during the process, one red, one black. The other two remained in tact. Can I solder them back on and if so, how?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@fixerchick those are most likely the power leads from the mic. Post some images of your board so we can see which wires are off. Use this guide Aggiungere immagini ad una domanda for that. It will allow us to see what you see. Of course, you can also take a look at this image
from here Flip MinoHD Battery Replacement to see if that shows the wires you are referring to.
Yes, those can simply be soldered back to the board. Check videos like this one or this one or this guide Come saldare e dissaldare componenti elettrici to get a feel for what you need to do.
Immagine Soldering
Guida
Difficoltà:
Difficile
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Flip MinoHD Battery
Guida
Difficoltà:
Moderato
15 minutes
Punteggio 1
Aggiungi la tua risposta
Celeste Gurney sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 29
Tutti i Tempi: 380
