Salta al contenuto principale
Processore quad core Intel Core i7 da 2,0. 2,3 o 2,6 GHz (fino a 3,8 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
580 Domande Visualizza tutte
Can I replace the trackpad on a Late 2013 15" MacBook Pro Retina?
My trackpad will work for about a minute or so after startup and then stops completely. Is it possible to replace this part? I don't see any parts or instructions on iFixit. Many thanks!
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
2 Risposte
Risposta Più Utile
While the Both the 13" & 15" models use the same procedure Sostituzione trackpad MacBook Pro Retina 13" fine 2013 to gain access to the trackpad (technically a touchpad). The 13” model uses a different part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad which won’t work in your 15” model.
You need this part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad.
@ajcooke01 - Replacing the full uppercase is not really needed here.
Immagine MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad
Prodotto
$69.99
Immagine MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad
Prodotto
$49.99
Punteggio 5
4 Commenti:
I have found that just replacing the cable works fine. There is very little that can fail on the trackpad. MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Cable
da
@mayer - Very true!
da
Please help. Macbook pro late 2013 edition trackpad = non responsive, keyboard response is delayed or non responsive. Can one replace just these 2 parts? Which other models are compatible if so. Where can I find replacement parts?
da
@margot23 - iFixit sells the trackpad, click on the correct part above 13" or 15" depending on your exact model.
da
I bought a new upper case for my late-2013 15" MBP. It included the keyboard but not the trackpad. I'm hoping these instructions for the 13" MBP will be all I need to transplant the trackpad to my new(er) upper case. I have a new battery to install too.
Punteggio 0
4 Commenti:
@reezekeys - Why are you replacing the uppercase?
da
I had a few keys of my keyboard stop working. I went to Ebay to get another one but found an entire upper case with keyboard in excellent condition for $9! It had no trackpad though. I also needed a battery so I got one, and figured I’d do both jobs in one shot.
da
@reezekeys - I would also replace the battery as well. Just follow the guide to transfer the trackpad.
da
I needed the battery for a long time, you know how that goes! Then the tab and function keys on my keyboard stopped working.
da
Aggiungi la tua risposta
gslive sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 7,629
