Salta al contenuto principale
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
20 Domande Visualizza tutte
Why my iPad doesn't go past Apple logo?
I have a A1430 WIFI + CELLULAR iPad which was running completely fine. However, it start discharging completely when the battery came down to 30% . Then , while plugging in to charge, first the red battery comes on followed by the Apple logo & keep going on loop. Doesn't charge or go beyond the Apple logo. Really frustrated & kindly requesting for suggestions. Pleasure
https://youtu.be/xx9VM6GMcnM
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Your problem appears to be a dead battery. It doesn't take a charge and it's not charged enough to boot the iPad. Considering the age of the device, this is completely normal. You can change it yourself, just check out this repair guide to see if your comfortable with all the steps.
Punteggio 2
Probably a dead battery, you should get it replaced.
I'm not sure if it could be a logic board issue because something similar is happening to my iPhone 5s.
Punteggio 0
Aggiungi la tua risposta
Robin Kalam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 104
