Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Annunciato nel marzo 2015 e lanciato il 10 aprile 2015, il Galaxy S6 era a quel tempo il top della gamma Galaxy. La versione con schermo curvo è nota come Galaxy S6 Edge.
493 Domande Visualizza tutte
Galaxy S6 Active IMEI error
Hello, I have a Galaxy S6 Active and its IMEI is showing up as 350000000000006. Does anyone know how to fix this and get its original IMEi number back?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
4 Risposte
Risposta Più Utile
@cabutcher99 so possibilities:
First----
Did you root and flash a 3rd party ROM?
IMEI corruption is known to happen a lot with these Galaxy S6.
If you did, flash back to stock ROM and it will resolve it.
Second----
EFS partition corruption
Try to flash the stock rom again.
If this doesn't resolve it, then you have hardware failure.
Third----
Run your real IMEI (sticker on the back of the phone) through swappa.com or imei.info to check the number.
If your phone was accidentally blacklisted, than you really do need someone to re-program to a different IMEI.
Obviously, make sure you backup your phone's data before doing anything. Use Samsung SmartSwitch to backup all your texts, etc. You can re-download all apps via Google Play Store later.
Punteggio 5
IMEI is corrupt (EFS partition), need to find someone that reprograms the IMEI back onto the device.
I've searched around and haven't found anyone able to fix 350000000000006 through firmware flashing, that's generic IMEI that appears only when the EFS partition becomes corrupt.
If you can find someone that does IMEI Repairs / has Z3X box they can fix up the EFS partition and put the IMEI back on.
Punteggio 3
My samsung galaxy 6 edge is showing SIM NETWORK UNLOCK CODE. How do i get it unlocked. My IMEI 350000000000006
Punteggio 1
Créer moi un compte IMEI
Punteggio 1
Aggiungi la tua risposta
CAB sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,508
