How do I replace the hardrive on a PowerBook G4 Aluminum 17
how do i replace the hardrive on a PowerBook G4 Aluminum 17
Questa è una buona domanda?
For the 17in model A1139 high resolution display PowerBook G4 use this guide: PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Hard Drive Replacement
For the 17in PowerBook G4 models A1013, A1052, A1085, or A1107 use this guide: PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
Look at the underside of your powerbook there should be a small label printed onto the aluminum which will tell you what model number you have. I hope this helps, good luck!!
Guida
Difficoltà:
Moderato
25 minutes - 2 hours
Guida
Difficoltà:
Moderato
30 minutes - 1 hour
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 771
1 Commento
What's you processor speed? There are five different machines that meet your description.
da mayer
