Salta al contenuto principale
Nel giugno 2017 Apple ha aggiornato il MacBook Air 13" con un nuovo processore Broadwell Intel Core i5, che ha permesso di aumentare leggermente le prestazioni e la durata della batteria.
423 Domande Visualizza tutte
How to remove a dent from the screen's back aluminium case?
My macbook air 13 inch felt from my lap, and the aluminium case at the back of the screen has now a dent on the corner.
Do you know how to remove the dent? Do I need to disassembly completely?
Questa è una buona domanda?
Punteggio 0
1 Commento
Do you have AppleCare + ?
If you do Apple will replace the display assembly for a fixed cost which is still cheaper than getting a new display your self and putting it on.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Sadly, The design of the lid is not designed to be that serviceable! Here's an older display to give you an idea how yours is constructed: MacBook Pro Retina Display Teardown.
Best to just replace the complete display assembly: Sostituizione schermo MacBook Air 13" di inizio 2015
Immagine MacBook Pro 15" Retina Display Mid 2012
Guida
Difficoltà:
Moderato
Immagine MacBook Air 13" Early 2015 Schermo
Guida
Difficoltà:
Moderato
45 minutes - 2 hours
Punteggio 1
I would not bother. Unless you have serious stoved in the corners or cracked the screen. It is easy to brake other components if you are not experienced repairer. I would put a sticker over it or get a vinyl wrap.
If you have don't have applecare but have full contents insurance on house you might be covered for electronic goods incidental damage.
Punteggio 0
Aggiungi la tua risposta
Max Echeverria sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,992
