Salta al contenuto principale
The Motorola Razr V3, also known as the Motorazr V3, was the first Razr released into the market in the third quarter of 2004.
Wont turn on and won't stop charging
So I plugged the phone in to a charger and it gives a flashing message sayiing charging battery. It's been plugged in for a couple hours now, I tried to turn it on a few times while on the charger, nothing, just gives me the same message. so when I took it off the charger it still wouldn't turn on. How Lin is it supposed to charge before you can turn it on? And shouldn't I be able to turn it on while still on the charger? It doesn't have a SIM card in yet, not sure if this affects any of that.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
- sim cards have no effect on powering on the phone, its should be on even without a sim card
- yes you should be able to turn the phone on while on charger.
so i suggest
1. remove your battery and reinsert it, then try to power it on and see
2. change the battery/ get a new one
Punteggio 0
Aggiungi la tua risposta
Kathryn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,207
