Salta al contenuto principale
Un discendente dello smartphone LG V10, simile all'LG G5, rilasciato il 29 settembre 2016. L'LG V20 si distingue per i numeri modello F800, H910, H918, H990 DS Dual, H990N Dual, H990 T, LS 997, US 996 e VS995. È disponibile con finitura titanio, rosa o argento con 32 o 64 GB di memoria interna.
51 Domande Visualizza tutte
LG V20 no gps signals
Does anyone know how to fix the LG V20 that can't pickup any GPS signals?
I tried to tighten all of the screws in the back plate, clean the contact terminal (even pushed it up a little bit) and the antenna terminal. In addition, I have tried the Aluminum trick by adding a layer of Aluminum between the antenna's terminal and the phone's contact terminal. None of these tricks fixed the issue. Also, I reset the phone, but no lucks. Any suggestions/recommendations are greatly appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Major GPS issues. High Accuracy is on.
this is only two months old. LG refuses to warranty because it is an "unlocked" phone! (what??)
Newegg won't help. I am DONE with LG. Never again. My G3 had really bad wifi.
Now really bad GPS. Also LTE cell reception is at least two bars lower than anyone around me is getting on the same network.
I liked this phone for the hi audio quality but bad reception and bad GPS is a deal breaker. Wish I knew this before I bought.
Punteggio 0
if you bought a refurb unit likely they put the wrong bezel on the top. takes like 3 minutes to fix. I fixed mine by adding copper tape from this link went from zero satellites to 10+ instantly
https://www.reddit.com/r/lgv20/comments/...
Punteggio 0
Aggiungi la tua risposta
Jack sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,528
