Low Pressure when pulling shot or steaming milk
The pump has been replaced with no improvement. I have flushed the system with vinegar, also no improvement.
At a loss of what to try next.
Questa è una buona domanda?
Hi Ken, is your steam wand or anything else leaking when trying to pull a shot? If so you'll need to resolve that before the group head will get the full pressure from the pump. If nothing is leaking then I would check to make sure your portafilter basket and group head screen aren't clogged, and perhaps try a slightly coarser grind on your coffee as well. You'll want to avoid using vinegar in the machine as it can reduce the life of the pump; use a commercial espresso machine descaler like Dezcal or Durgol instead.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 211
