cracked screen 75 inch veon LCD
How much would it cost to fix a 75" LCD veon yps75uhd need aquote please
Questa è una buona domanda?
Hi @tuakama123 ,
TV display screens cannot be repaired if they are cracked. They can only be replaced.
It costs nearly as much to get a replacement panel for a TV as it does to buy a new TV, if you can find one in the first place that is.
You could try disconnecting the power from your TV and then removing the back cover to locate the panel number that is usually printed on the back of the panel.
Once you've found the number search online using the number to see if there are any results for suppliers.
Do not be surprised if there is only results for display panel manufacturers.
Plasma / LCD / OLED displays etc are manufactured by specialist panel manufacturers for the TV manufacturers and usually they don't sell one-off panels.
The best option is to advertise your TV as faulty- good for parts-cracked screen to try and recoup some of the cost of a new TV.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 26
Tutti i Tempi: 7,295
3 Commenti
can I get my veon cracked 55 inch screen fixed
da tuakama
@tuakama123 same answers as for the original question applies to your TV. You can replace it but you have to try and find the right panel etc.
da oldturkey03
I have 75 inch Sony bravia HOW MUCH WILL IT COST TO FIX ONCE I GET THE REPLACEMENT SCREEN
da novatheprofound
