Salta al contenuto principale
The Buick Rendezvous is a mid-size crossover SUV that was sold for the 2002–2007 model years.
Why does my car cut out when I press the gas hard but I let it go it's
I try to pass a car so I hit the gas hard but it bogs out so I let up on the gas it's fine. As long as I press it easy it's fine. It's a 2007 RENDEZVOUS CXL
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks I'll try it today
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Probably either a bad fuel pump , bad pressure regulator or a dirty fuel filter. Id start with replacing the fuel filter. Then get a pressure reading on the fuel line and also on the fuel rail if these fluctuate as you rev the car then its a bad regulator if the pressure is low then its a bad pump. Hope this helps
Punteggio 4
Aggiungi la tua risposta
Jimmy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 20
Tutti i Tempi: 198
