Determining U2 or Tigris failure on an iPhone 6
Hello,
Just looking into an iPhone 6 and the device boots and behaves normally, it draws between 0.08mA and 0.50mA. It changes the battery icon when the cable is plugged in.
Tried 3 computers, 2 different cables and 2 connector ports - same results.
I would typically suspect U2 if it was drawing 0.00mA.
From reading, Tigris is the element that deals with USB communication.
The voltages around this area are ok, theres a 1.8V, VCC_Main, USB5V0. none of the caps around here read anything different when normal.
The USB connector on the board itself is physically clean enough.
Before going ahead with a U2 swap I am wanting to know is it best to swap Tigris first because to me this seems like the most likely culprit.
Thank you :)
Questa è una buona domanda?
