Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
not sleeping on lid close
Ever since I replaced the thermal paste on the system board (see "reflow" procedure - very involved and requires completely removing system board from laptop - all cables removed, etc.) my laptop hasn't been sleeping on lid close.
It will sleep if I select it from the menu, or eventually as part of the Power Saver prefs, however.
Is it possible I left a cable loose and if so, which one is it?
Could this be fixed by a pram reset?
Anything else to look at?
It's been running great with new thermal paste, no longer panicking on video issues.
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The HD SATA cable holds the Hall Effect sensor with the IR sensor. I would recommend you first try replacing the cable MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement hopefully you didn't damage the logic board.
Punteggio 2
2 Commenti:
Thanks! Would this affect the IR sensor as well, then? I have an old mac remote I could test this out with.
da
It might, if you ripped or damaged the ribbon cable. I do recommend placing some electrical tape down on the uppercase where the cable rests.
da
Aggiungi la tua risposta
Robert Campbell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 174
