Why is the wifi and the bluetooth signal weak?
Hi!
I am the only one in the house with this problem - When I go to my room, the wifi-signal on my iPhone disappears. I only have wifi-signal if I am in the room, where the router actually is. If I bring another iPhone or iPad to the room, they still have a good wifi-signal. And no, it has not always been like this. It started like 2 months ago.
I have another problem - the bluetooth-signal is bad as well..
What to do?
Questa è una buona domanda?
5 Commenti
Replace the wifi/gps antenna and you are good to go.
da nicolay.94
I have the same problem too, the wifi router is in the living room but when i go even in the kitchen the wifi signal disappears from my iphone much more when i go upstairs. Do u know how to fix this?
da April Markenly
I have a question: When this started happening for you, did you drop your phone, or did anything hit it? This also applies to anyone else reading this with the same problem. I have this problem, and my phone fell off my bed and then it started to stuff up. The night before, I was having a bit of problems with my Bluetooth headphones, but my Bluetooth signal tends to go weak every so often, I thought it was normal. That night, I was able to connect to the wifi from my room, but after my phone dropped, I have to basically put my phone to my headphones for them to connect (other devices are fine), and I have to be standing no more than four metres from the wifi router for my phone to connect.
da ღ Pumpkin Pixie ღ
well my phone was a litte in the wate r but I thought this was no problem because it kept working. Should I get a new phone or fix this one? I have a 6s
da Radu George
My phone dropped and my screen broken and ever since then I’ve been having issues on the Bluetooth and WiFi signal
da Cynthia
