Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1182 Domande Visualizza tutte
Suddenly popping, crackling sound.
I got this Macbook as a leftover from my dad. About one-and-half year has passed.
And now I found my speaker popping some weird sounds. Or you can say, it's the frequently asked crackling sound.
This happens several minutes after I turned on my Macbook. But after I left my Macbook for about 10 - 20 minutes, it doesn't happen again. The crackling sound disappeared for a time.
What do you think about this phenomenon?
Should I ignore it? Or should I go to the Apple Store?
Questa è una buona domanda?
Punteggio 4
2 Commenti
I also have this issue, your solutions seems to work, I believe your going to be fine not bringing it to the Apple Store.
da
I am same problem with Macbook 2018
waiting for proper solution
Thanks
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Ive tried fan control, PRAM reset, diagnostics ect and finally gave in...took the macbook apart and saw that there was gritty dust in the fan, flushed it out with isopropanol alcohol and its been running smoothly ever since and the popping sound has gone
Punteggio 1
Fix the disintegrated voice coil flexi ring with flexi white glue.
Punteggio 1
Aggiungi la tua risposta
Sulthon Hernanda sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 9,846
