Won't pump out water without resetting main switch
Have an issue with a Series 90 Kenmore Washer.
It turns on when the main selection switch is pulled out, the tub fills and the washer agitates and washes normally as expected.
The problem occurs when it should continue on to the pump out and rinse cycle. I now have to turn the main selection switch off and then immediately on again before it will go into the next cycle of spinning and pumping. The coupler was replaced but this did not remedy the problem.
If you know what might fix it I would appreciate the help.
Thanks
And it's still the BEST washer Ive ever owned and there have been a few, so this is a keeper!!
Questa è una buona domanda?
1 Commento
I'm no expert but it could be the timer control that is faulty.
da sm_vulkus
