Here is a chart I created for Verizon iPhone 4S.. Does not include the 6 screws and washers holding the LCD to the mid frame, since you do not need to remove them ..
Size Type Location
3.6 mm - Pentalobe - Dock Connector
1.5 mm - Phillips - Battery Connector
1.8 mm - Phillips - Dock Connector - Logic Board
1.6 mm - Phillips - Logic Board near vibrator
1.3 mm - Phillips - Rear Camera - Red
1.5 mm - Phillips - Rear Camera - Orange
2.4 mm - Phillips - Rear Camera - Yellow
4.8 mm - Flat - Top near headphone jack
2.5 mm - Phillips - Top near power button
3.4 mm - Phillips - Near vibrator motor - Red
3.6 mm - Flat - Near battery - Orange
2.4 mm - Phillips - Speaker enclosure
1.6 mm - Phillips - 1 of 4 corner
1.6 mm - Phillips - 2 of 4 corner
1.6 mm - Phillips - 3 of 4 corner
1.6 mm - Phillips - 4 of 4 corner
Details:
Size Amounts Type
1.3 mm - 3 - Phillips
1.5 mm - 2 - Phillips
1.6 mm - 5 - Phillips
1.8 mm - 2 - Phillips
2.4 mm - 3 - Phillips
2.5 mm - 1 - Phillips
3.4 mm - 1 - Phillips
3.6 mm - 2 - Pentalobe
3.6 mm - 1 - Flat
4.8 mm - 1 - Flat
Total 21
17 Phillips
2 Pentalobe
2 flat
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
