Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
321 Domande Visualizza tutte
What does the top case consist of?
Just curious as I've been heard because of issues with ports, the whole top case needs replacing.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
6 Risposte
Risposta Più Utile
Excuse me.
Do you know if the top case consists of the speakers? Apple will replace my top case and I wonder if the speakers are going to be replaced.
ps: MacBook Pro 15" Touch Bar 2017
Punteggio 2
2 Commenti:
If you are having the uppercase replaced as far as the extended warranty program for bad keyboard then yes the speakers, battery and trackpad are all replaced within a refurbished uppercase.
To be clear you are not getting a new part just refurbished one. They replace the keyboard and battery as well as test the rest of the part before reusing it.
da
Thank you! Really appreciate it!
da
The case parts are made from aircraft grade aluminum.
Can you explain more fully what your issue is. How about posting some images so we can see the damage. The USB-C ports are mounted to the uppercase independently.
Punteggio 1
Yes. The top case includes a new pair of speakers. I don’t know if this always happens, but my MBP 15” with TouchBar 2017 top case was recently replaced by a new one in a local Apple authorized service provider and it included: new battery, new keyboard, new speakers.
Punteggio 1
2 Commenti:
did it include a new touchbar?
da
@Arch Mauricio Bermudez - Yes, it is part of the uppercase assembly.
da
Ports are on the logic board, which is mounted in the top case.
Top case is mainly battery, keyboard and some other small components.
It should be under warranty if your model is this new
Punteggio 0
Hi,
My MacBook is now under repair before the end of the 4 years period.
do they replace the top case with same butterfly keyboard or something different?
Thanks
Punteggio 0
Very late but I'm wondering this as well. I've been told to replace the top case from Apple but my issue is crashing does that tally up?
Punteggio 0
1 Commento:
@tr0llboy - That doesn’t make sense!
What is the crash reports telling you?
da
Aggiungi la tua risposta
John Hamp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 100
Tutti i Tempi: 47,482
