Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacement home button doesn't work
I replaced a iPhone 6 screen & the screen/camera/Speakers are all functional but the home doesn't work at all - nothing. My client came to me with out a home button so I cannot test the original. Is the new button defective or is the software glitching out because it hasn't had a home button in a while.
Questa è una buona domanda?
Punteggio 1
3 Commenti
A replacement home button should function the same as a regular home button with one exception-fingerprint ID will not work. As far as glitching? A hard rest should solve the problem. Ensure the replacement is for the six.
da
Im getting no functionality at all - I can't do a hard reset without a home button
da
You can do a hard reset if you turn on Accessibility. It will place a home button on your screen. Then just find the option to restart the phone.
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
I would guess the home button to be the defective part.
Punteggio 1
1 Commento:
I will change it out and see. will update. Thank you
da
Risposta Più Utile
Could be homebutton, but could also be the longflex running along the screen
Punteggio 2
4 Commenti:
The screen is brand new would that make the new screen defective?
da
its not the actual screen but the metal plate with the ribbon thats attached to the back of the lcd
da
What Daniel said. If it came with the screen, then even higher chance that it does not work as it is likely a cheap part
da
The button was defective - replaced the button (again) and it was fine
da
Touch ID isn’t functional after an screen repair if the home button is replaced.
Punteggio 0
1 Commento:
I’m not looking to use Touch ID - just use the button for its other functions
da
ensure the cable on the thermal plate is working, try another cable-ensure the socket where the home button is plugged into isn't damaged- try a replacement home button know to work with the iphone six remember the touch id will not work -all other functions should.
Punteggio 0
Aggiungi la tua risposta
jeanise sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,106
