Salta al contenuto principale
The Ford Explorer and the Mercury Mountaineer were both updated for the 2006 model year on a new frame, produced by Magna International rather than Tower Automotive.
Why is my ABS locking up
When my ABS system is connected and my abs fuse is in I can’t go over 5 mph without it locking up, my abs light is on with a wrench symbol. What would cause this? If I disconnect the abs and take the fuse out the vehicle drives fine.
Questa è una buona domanda?
Punteggio 1
3 Commenti
We just bought our 2009 Ford explorer Eddie Bauer edition 4 months ago & last week it started locking up its braking on it's own & showing the abs light & a orange wrench on the dashboard. We have replaced the brakes, brake lines, brake calibers & it is still doing it can someone please help us that knows what is causing these problems! Thank y'all!
da
I just gotvahold of a 06 explorer and trying to figure out were the fuse is so I can move mine but not sure we're the fuse is been looking online and no luck please could some one point me in the direction I need to go
da
On my 2004 there clunking in front an my abs light an once in awhile 4x4 high comes on when the sounds go off what can be
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
This just happened on my 2006 Ford Explorer 4.0 4x4. My abs, traction control, and wrench lights came on. I stopped but when I tried to drive the 4x4 light came on and the brakes were engaged by themselves. The only code my car was throwing was C1233…left front wheel speed sensor imput signal missing. I changed the abs sensor and it didn't fix it. It ended up being the hub.
Punteggio 1
2 Commenti:
What is a hub?
da
Your hub? Do you mean the wheel bearing? I just changed 3abs sensors and my 06 Ford explorer is doing the exact same thing. But the wheel bearing was replaced by the dealership before I replaced the sensor. So it's new, but that is the sensor causing the trouble. I would like to know why this is happening
da
It is possible that you have a sensor that is faulted out or the abs module is bad and needs replaced. If you remove the fuse, you cut the power to the abs system which will not make the abs system in use when you need to break hard. My best opionion because this is part of a safety system for a vehicle, you need to take it to your local Ford repair shop and have them to run a diagnostic on it.
I found this from another forum from Ford. This might help you out. Just remember, you will still have brakes, just no ABS when you have to brake hard.
https://www.justanswer.com/ford/4ilso-fo...
There is a pinpoint test in there that might help you figuring it out.
Punteggio 0
I changed the entire hub assembly. It was under $100. I put a good one in by Timken. It came with a brand new ABS sensor too. It fixed the problem immediately.
Punteggio 0
Aggiungi la tua risposta
Tara Crane sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 106
Tutti i Tempi: 16,112
