LN46D630M3FXZA Odd Display "Banding"
Greetings,
This question is in regards to a 2011 Samsung model LN46D630M3FXZA. I purchased the television new in 2011 and have been very satisfied. One day, when powering on the device, these odd vertical "bands" appeared. The device was not damaged or struck, there was no contact with moisture and no issue with power. It simply "happened".
Does anyone know what the issue might be?
Does this sound like something worth repairing?
Questa è una buona domanda?
Okay ..you are going to have to assume this is hardware related then...I am not sure of the configuaration of this particular set but here is a starting point....ebay the model number and look at replacement parts ...video board or mainboard...because the chances are moisture has shorted a component and trying to diagnose which one will take time which adds to cost if you use an engineer....try this link and size up what you are happy to spend or by a broken screened version in your locality and swap out the bits you need..
https://www.ebay.com/p/Samsung-Bn96-1977...
da john cordey
