Salta al contenuto principale
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
49 Domande Visualizza tutte
My camera was rained on. Is there a guide to take it apart and fix it
looking to take apart my camera and replace anything water damaged....wanted to do myself to learn how to repair my own camera without paying 300 to 500 from canon
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Kit riparazione batterie MacBook
A partire da $69.99
Buy Now
A partire da $69.99
Buy Now
2 Risposte
Soluzione Prescelta
Hi,
Here is a link to the ifixit Canon EOS 60D Repair guide.
Be sure to use IPA (Isopropyl Alcohol) 90%+ to clean and disperse any moisture from the electronic components etc.
Here's a link that may be of some help to you
Electronics Water Damage
Also be gentle when handling and take your time.
Hopefully this is of some help
Punteggio 2
First thing is to remove the battery and leave it off until you have throughly dried out the device.
If the camera fails to come to life...it might be worth using the same method mobile phone repairers use..bathing the logic board in iso alcohol.if this fails to rectify the problem...be aware....
Canon logic boards have two sets of fast blow fuses...which means generally only one will blow.there is information on google as to the location of these mini fuses.
Punteggio 0
Aggiungi la tua risposta
Stephen Antholzner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 43
Tutti i Tempi: 884
