Salta al contenuto principale
Released March 2016, 7.0" Galaxy Tablet by Samsung.
Why can't I update any apps?
My tablet does not have the Google play app on it. It is an SM-T280 I've tried doing a software update along with trying to download the app from my browser with no success. Without the play store, I can't seem to update apps, or install apps. Anyone have this problem also? Or know how to fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You likely have a model from mainland China.
The easiest away around this is to install the Amazon app store and use their store.
• go to Settings --> Security --> enable Apps from Unknown Sources.
• download amazon app store from https://www.amazon.com/gp/mas/get/androi...
• use the samsung file manager and install this apk
Otherwise, here is how to get Google Play Store.
• download http://www.apkmirror.com/apk/google-inc/...
To download each APK file, just click on the link, and then scroll down where you’ll see Download APK. Click that.
Install the above 4 files with the Samsung file manager in the following order:
Google Account Manager APK → Google Services Framework APK → Google Play Services APK → Google Play Store APK
You should see the play store on the home screen now.
All you have to do now is just tap on your new Google Play Store app, and sign in with your Google account.
You may find that it might not work at first, but it will be alright after you’ve signed in.
Punteggio 1
3 Commenti:
I have tried repeatedly to download the play store app itself and all I get is a little sign that says that it wasn't installed. It worked wonderfully for the amazon app but i was really hoping to get the Google play app :( the amazon app just doesn't have some of the stuff that Google does
da
But thank you so much for the help
da
@alexf1x1t, did you install all 4 files I provided in the exact order? If so, try a a different google play apk. Apparently, there are 4-5 variations. One of these should install.
https://www.apkmirror.com/apk/google-inc...
da
Aggiungi la tua risposta
alexbushell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,762
