Salta al contenuto principale
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 Domande Visualizza tutte
Is it ok to use isopropyl alcohol 98% for OP5 back?
so i have this stains in almost every side of my phone back, i think its from the case i bought but i dont know and i wanna try to clean it with isopropyl alcohol 98% is it ok, my worry is would the paint rub off?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Iso wipes or using the alcohol on a soft towel is OK to use. If you find that the wipes don't clean it good enough dawn and water on a soft towel with very light rubbing will do it. As you long as you lightly rub/wipe it the paint won't come off. Tip:Don't use bathroom towels. Microfiber is your friend here.
Punteggio 0
2 Commenti:
So just use microfiber towel and isopropyl alcohol? Should i mix the isopropyl alcohol with something, like water?
da
No, don't mix the alcohol with anything.
da
Aggiungi la tua risposta
Gamas Lazuardi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 357
