Salta al contenuto principale
The eighth generation of the Mitsubishi Lancer.
50 Domande Visualizza tutte
How do I get my car to accept brake fluid after replacing the master c
Replaced the mastercylinder on a 03 Mitsubishi oz rally I cannot get it to accept fluid help
Questa è una buona domanda?
Punteggio 0
1 Commento
@lwalling64 what do you mean by "cannot get it to accept fluid"? the fluid does go into the reservoir?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The best tool you can have for breaks would be a vacuum bleeder. It comes with a reservoir you place on the master cylinder tank and then you go to each wheel and suck the fluid through. No pumping of the brake needed!
This would also help if you have an air bubble in the master cylinder that’s preventing the brake fluid from getting into the piston to be pushed out.
You can find these pretty cheap at a harbor freight or similar store.
Punteggio 1
Aggiungi la tua risposta
Lwalling64 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 46
