I can not enable the video mode
when the screen comes on a little display comes up in the top left corner that says video mode disabled. i have done the on volume button thing with no results
Questa è una buona domanda?
Rob Vitale start with a hard reset. You will lose your files like pictures, music etc. when you do this.
You need to hold down the volume up button then press the power button for a few seconds until the tablet turns on, releasing power button, you should now be getting the recovery menu.
after i did that. the screen came up with...magicware mismatch. critical failure, unable to start kernal. unrecoverable bootload error. whitch means is that it is stuck in a loop.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 106
2 Commenti
Rob Vitale by this "done the on volume button thing " you mean a complete hard reset?
da oldturkey03
Ok. I hold the on button and hold the volume down button. It goes blank. Then it comes on for 1 second and on the screen it says that the UI launcher has stopped. Then freezes up. I did the same thing with volume up. It's not happening. All I wanted to do is clear the cookies and reset the app. preferences.
da Rob Vitale
