Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
321 Domande Visualizza tutte
Why do all video players stop moving
Whenever I watch something on the internet the video will stop but the audio will keep playing, the video will only start moving again when I move the mouse and I don't know why this is happening my computer is fairly new so it shouldn't be any processor problems
Questa è una buona domanda?
Punteggio 0
6 Commenti
Does your screen go all black?
da
What is your OS Sierra or High Sierra?
da
no, the video just stops until I run my cursor over It
da
And your OS is???
da
The OS is Just Sierra
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is two possible issues here:
The first is the reliability of the connection to the source. This could be the server offering the stream all the way to your system via all the networks it crosses. The data stream breaks down enough the video part is unable to recover. If you back wind the vid to a section that was good it should recover.
The other possibility is the player is unable to buffer enough of the stream. This gets into how much RAM you have and available drive storage and if the connections data rate is very low it too can effect things. Ideally, you want to buffer in RAM, but if your lean on RAM as other apps are using it your drive will be used. If the data rate is low you may need to allow your system to buffer the vid before playing it.
Punteggio 2
Aggiungi la tua risposta
Batz Man sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 448
