Ipad 4 not charging and not starting
Dear tech-people,
my Ipad 4's battery has reached 0% two days ago. As usual I attached it to the original charger (with non-original cable) but it would neither charge anything (just stay as in the attached picture) or boot. After inserting the cable and after pressing the power button the attached picture appears on the screen for two seconds but nothing else. It stayed on the charger for around 24h now without any changes.
I have already researched a little and have tried a second cable, charging dock and cleaned the lighting adapter (nothing noticable came out). I also tried the different combinations of pressing the power and home button, but the Ipad would just stay in the state as in the picture.
I have run over this tutorial from 2012: Ipad Dock connector no longer working
Does anyone know if this procedure would be applicable to the Ipad 4 too? Any other ideas?
Thank you a lot for your help!
Best regards
SadIpadUser
Questa è una buona domanda?
Did you try the actual Charging block that the charging cable pluygs into. Sometimes those can go bad. .. If so I would try another charge port inside the ipad itself. Its showing that it reads it was connected , but not actually charging so If you already tried a replacement. I would try a second before rolling it out. Last thing I would try is a battery. If none of this works, then it's possible something on the logic board shorted out.
da service
