Salta al contenuto principale
First unveiled at the 2005 Frankfurt Motor Show, The Audi Q7 is a seven-seater, three row, mid-size luxury SUV manufactured by Audi.
Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
it was the ecu got water damage dont know how but it did
Punteggio 0
3 Commenti:
How did u find out it was your ecu?
da
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
da
Life saver!!!!!!!
da
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
Punteggio 0
1 Commento:
after having accident (a crash) with my Q7 it stop and didnt crank again. any solution?
da
Aggiungi la tua risposta
carlos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 98
Tutti i Tempi: 3,619
