Salta al contenuto principale
Xbox One S, progettata da Microsoft Corporation, è stata rilasciata ad agosto 2016. Xbox One S è una riprogettazione di Xbox One.
427 Domande Visualizza tutte
How do I fix my broken xbox one S sync button?
Okay so i figured out around two days ago i tried syncing my controller to me xbox one S but it wouldnt work i pressed the sync button on my xbox and i couldnt hear a click sound it makes normally when you sync a controller is a peice missing or is my sync button broken?
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
14 Risposte
Risposta Più Utile
Plug Controller in USB.
2. Hold Power Button for 10 seconds.
3. Unplug the Power Cord for 10 seconds.
4. Plug Power Cord back in to Xbox.
5. Power On Xbox Press Power Button on Console.
6. Soft Power down Xbox Press Button once.
7. Disconnect USB from Xbox and Controller.
8. Power on Xbox with Controller.
You're Welcome. Enjoy!
I found this on a different page and it worked!!!!
Punteggio 13
20 Commenti:
Didn’t work At all
da
It worked for me
da
It works! Thank you sooooo much
da
dude instructions are so unclear that its not even funny
da
This didn’t work at all dude actually post something helpful
da
Mostra altri 15 commenti
With mine all I had to do was take the disk out and boom problem solved so make sure there's no disk in when ur trying to sync.
Punteggio 2
2 Commenti:
Same I was really suprised
da
thank you sm for this you fixed my issue
da
How to fix the problem and it’s broke
Punteggio 1
1 Commento:
Use a pencil, when it broke off when I touched it with my finger, I used a pencil and it worked
da
You can get a new one but you can also sync your controllers by using the USB port in the back of the Xbox One mine is broken as well so I just use the USB port to sync my controllers to the Xbox
Punteggio 0
2 Commenti:
okay thanks for letting me know but how do i sync my controllers to my USB by the way im jack nutter who asked the question i just had to switch my profile though
da
How do I do this?!
da
I know this space is for an answer but I'm having major problems with the sync I press it and it clicks but it doesn't flash plz help
Punteggio 0
3 Commenti:
Mine does that aswell and it’s annoying as because I can’t play Xbox now
da
Me too, someone help!!!
da
connect a usb cable to the controller and the usb port on your xbox. Try all of them, as on my Xbox One there is one that doesn't work
da
Other answers worked finally. Annoying product
Punteggio 0
yes but is broken and this is not working
Punteggio 0
There's 2 Sync Buttons, one to the left of the power button, and one below the power button on the black base, the second one is the one you have to press in order to pair any device you have.
Punteggio 0
1 Commento:
Where is this second sync button and how do I use it?
da
I took mine apart and found the actual bind button itself had fallen away from the board. I haven’t mustered up the courage yet to attempt to solder it back on, but I have a feeling that is the only way to fix it.
Punteggio 0
There should be a USB plug in on the back of the Xbox. So grab the charger you use for the controller and plug it into the back and plug it into your controller. It worked for my brother.
Punteggio 0
Hard reset the Xbox, no data will be lost other than cache, it might work after.
Punteggio 0
When my sync button quit working I replaced the rf module. Only cost me like 30 dollars for that and the tools
Punteggio 0
idk if this will work for you guys but I moved everything in front of my xbox and made sure nothing blocked the pairing sensor and put my controller super close to the sensor and it worked
Punteggio 0
Address:
Peer Shaheb Lane, Dhaka 1217
Phone:
01798-777803
Website:
https://nashidbashar.com/seo-expert-in-b...
GMB:
https://g.page/nashidbashar
Nashid Bashar is a Clickminded certified SEO expert in Bangladesh. He is serving as an SEO consultant in California-based Company ProAir Industries, Inc.
Punteggio 0
Aggiungi la tua risposta
Jack Nutter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 137
Tutti i Tempi: 48,577
